you could take a stick or pice of metal (aluminum is easy to cut), cut a slot in it and then insert some emery cloth and whirl it around as you zip up and down a little. 45 degree cuts would be good; in practice just a little roughing is what you need to break the glaze or polish from the old rings and let the new ones in. only a little is needed, just to "scratch" the surface. I'd definitely break the polished surface somehow.
Big and small, I like them all....bikes that is...
