Turn Signal Housings
CopperCollar
Post by CopperCollar »
I have been looking for turn signal housings for the 80. Ebay is out of the question, big bucks for questionable condition housings. There are the aftermarket reproductions for a pretty reasonable price but they lack the Stanley embossment.
Here is what I started with:
As one can see a they were poorly painted. I was faced with finding a method of salvaging these. One was sanding but then I would not get the paint off the Stanley embossment. Another way was using some stripping method, Aircraft stripper out of the question, heat gun...maybe.
I have access to a bead blaster at work and so it goes. I used fine glass beads with 40 psig and gently worked the blasting process to remove the old paint and oxidation.
This is after glass beading at 40 psig:
Looks pretty good so far but now I have to bring out the original sheen.
Here are three of the housings after being worked with Mother's Back to Black and a green Scotch Pad:
Not perfect but they will certainly pass for restoration.
Hope this gives others an option to try out.
Re: Turn Signal Housings
Fantastic as usual Mike. You are nothing if not resourceful and creative.
Great job Mike!
