I'm still working on restoring a decent 79-80 Frankenbike. I dissassembled the fork over the week-end and I noticed one tube was showing more resistance than the other. I see 2 clear spots on the inside of the fork slider. I can't really tell if this is normal casting shrinkage or if something REALLy bad happened in the past. I did have to bully the fork to pull out the seal, I think it was the original piece and that fork never been serviced. The stinking green goo I cleaned up tells me it never was (grossiest non-body fluid I've ever seen!
My question is : is this damage too important to have a safe/reliable fork assembly? I don't plan to have it filled and machined since I have access to a second bike for parts ('79 though). I assume I can use the slider from the '79 or the whole fork assembly. I prefer the cross-drilled discs but I also assume they are interchangeable.
Comments?
Side note : the internal components of the damaged fork are in decent shape. The bottom piece (looking like an empty gun shell) do look a bit damaged compared to the other side of the fork. I haven't found any debris in the dropped fluid, weird... that bike wasn't functioning when I got it so I can't comment on the ride or if the fork worked correctly.
and bonus!
