Boomerang wheel & brake rotor problem!
jomi32
Post by jomi32 »
Hi, I got problem to set front boomerang front wheel to my -79 Z with std. forks & rotors. In this combination the rotors are too wide there is no space between rotors and forks. I find out that the normal rim is in the midle thinner ca. 12 mm than this boomerang wheel from CX 650. I want to use normal forks and calipers so which brake rotors shall I set there?
Live every day happy, even your life will be one day less! Said by: Major Larry A. Thorne
Same in Finnish: Ilosest ellää pittää vaik päivää vähemmän! Capt. Lauri Allan Törni from Finland
