Hey all,
My alternator cover gasket gave up the ghost and when I tried to order a new one, I found it was discontinued. Do you folks have any tips or tricks for cutting a new one out of a sheet of gasket material? It'll be my first time.
Gasket sheets
Re: Gasket sheets
If it is part #27- 91302-422-000 i have a spare new one i can send you.
Check the number here: http://www.ronayersmotorcycles.com/fich ... veh=132865
Re: Gasket sheets
Thank you for the offer! Unfortunately it's #15 on that list- 31140-422-306. I ordered the part from Ron Ayers whom informed me it was discontinued. I have yet to tear into it, though, so I may contact you if I end up needing #27.
Re: Gasket sheets
I was able to dig a few of these up. But the vendor made me pay dearly (probably because they were discontinued). They are $25.-/piece.
Re: Gasket sheets
siriusconinc.com has them also but you have to buy the complete gasket set for $99...If you need a valve cover gasket and end cap gaskets they are in the gasket also. The valve cover gaskets are 65 at honda alone.
Re: Gasket sheets
Found one of those as well at the bottom of the box.onewheelskyward wrote:Thank you for the offer! Unfortunately it's #15 on that list- 31140-422-306. I ordered the part from Ron Ayers whom informed me it was discontinued. I have yet to tear into it, though, so I may contact you if I end up needing #27.
p.m. me your address and i will send it to you.
- cbx6ss
Re: Gasket sheets
bump.
just ordered
Freedom Honda
732-671-1073
Spoke with Parts Manager, "Colleen"
$17.50 to my door.
/r
Brad
just ordered
Freedom Honda
732-671-1073
$17.50 to my door.
/r
Brad
