Has any one ever took on the challenge to repair a low reading volt meter, my 79 shows just over 12 volts at the meter. When I place my DVOM on the battery it shows 14.4 volts off idle.
What's inside the meter to show this current, or is this a replacement only to fix it.
I sure would like to see the actual reading, any suggestions ?
Thanks, Marc
Volt meters
- sr71cbx
Voltmeters........
Hey Marc,
I believe a standard 2 in.diameter aftermarket automotive gauge will fit in the stock location.I've seen it done before.Use a Stewart/Warner or AutoMeter gauge,they work the best.The stock Honda voltmeter is notoriously inaccurate,they all read about a volt low.
Hope this helps,take care & ride safe.
----------Mark Miller#0938
- HondaCBX6
Voltmeter
Make sure all connectors are clean and making real good connection. A couple Ohms of contact resistance can skew the meters readings.
Remember when baseball cards in the spokes transformed any bike into a motorcycle?
- Don
- Amazing Poster
Voltmeter off
Why bother changing it? If you know that it's a volt or so off , and you know what it reads when you get 14 1/2 or so measured to the battery to the battery, just use it as a trend indicator. You know where it's charging.
Davey
