Guys,
I would like to know if a 80 wire harness has different left and right switch connectors than the larger switch connectors on the 79 harness. If someone has a pic of the headlight end of the 80 harness that shows the switch connectors, that would be great. I'm thinking it is the smaller plug connector, but maybe that did not start till the 81/82 model.
JT
79 / 80 Wire Harness
- jt
JT In Texas
the mirror every mornin'.
Re: 79 / 80 Wire Harness
No difference, they are the same as a 79.
- jt
Nils,
Thanks for the reply !
JT In Texas
