Sorting keys on my 79 Z
Kool_Biker
Post by Kool_Biker »
Did all 79s have one key for ignition, fuel cap and the helmet holder?
Thanks, Aris
Aris Hadjiaslanis
ICOA # 6309
Berkshire, Windsor
tevan
Re: Sorting keys on my 79 Z
Post by tevan »
All the ones I have had did.
All my CBXes did too. The 80s in addition had the tail-lid with the same key and the Prolinks the saddlebag locks and mounting and right side fairing pocket.
Kool_Biker
Then as expected mine's a mess:
Can you shed any light at all on which one is of the right type and which is/are not?
Hint: Am I right in thinking the slotted part of the ignition key should be on its other side (mirror image), as is the case with the tank & holder keys?
Cheers, Aris
Aris Hadjiaslanis
ICOA # 6309
Berkshire, Windsor
The fuel tank key is the original CBX key.
The steering lock was a European option and we do not have this in the U.S. Could be that this is original. The helmet holder key is a Honda key, but not for a CBX. Maybe somebody had a blank cut.
The ignition key maybe from an ignition lock for a different Honda. Some of the Goldwing locks fit the CBX.
Joner
Post by Joner »
The steering lock on the euro bikes (in the frame) had the key you have for it.
Cheers
Chris J.
Grey-haired bikers don't get that way from pure luck.
Kool_Biker
Thanks chaps all this is useful.
Am I correct about below??
Kool_Biker wrote: Hint: Am I right in thinking the slotted part of the ignition key should be on its other side (mirror image), as is the case with the tank & holder keys?
Armed with this knowledge I will now begin changing and adjusting the locks to end up with one key for the first 3 functions - ignition, fuel, helmet.
Which is, to say, is far less interesting than rebuilding my engine (for those who know my perils), but infinitely less stressful :whistle:
Aris
Aris Hadjiaslanis
ICOA # 6309
Berkshire, Windsor
Kool_Biker wrote:Thanks chaps all this is useful.
Aris
You would be correct, assuming the same key operates all items.
Kool_Biker
I was afraid ..
So, I begin with a correct new / second hand european ignition lock, and after, I adopt the fuel tank lock to the former's key.
The helmet lock & key, a much lower priority, can wait.
Thanks a lot!
Aris
Aris Hadjiaslanis
ICOA # 6309
Berkshire, Windsor
Kool_Biker
Folks,
I've looked and looked into our site regarding the subject of removing the tank lock barrel and what I found (above) was interesting if, to me at least, too vague.
Is there a more detailed, more up to date description somewhere I missed?
As before, my objective is to modify the tank lock to work with my ignition key.
Many thanks
Aris
Aris Hadjiaslanis
ICOA # 6309
Berkshire, Windsor
Kool_Biker
Easy peasy folks.
The tank lock barrel comes by gently pushing back its top-most (spring loaded) blade and pushing down, as shown in the attached pics.
Then it's all about swapping the 5 little main blades around and using your best miniature files to re program the lock.
Hope this helps.
Aris Hadjiaslanis
ICOA # 6309
Berkshire, Windsor
Yet Another Pearl from you Aris. So nice to have you back.
desertrefugee
Post by desertrefugee »
Good lord. The man's an animal. (I mean this in a good way).
Not too many "average Joes" willing to reprogram a lock cylinder.
Well done sir. You must have lots of time on your hands!
Kool_Biker
Hi Nils,
It's the challenge and the great pleasure that follows when a small problem is solved.
I looked everywhere and could not find this info. So ..
BTW, thanks for all the great tips and equally great photography in RestoCycle! :text-+1:
Aris Hadjiaslanis
ICOA # 6309
Berkshire, Windsor
Another gem, Aris! Thanks from all of us.
