Steering head bearing replacement
- ajs350
I am replacing the steering head bearings on my 80 but have come to a stop as I am having trouble removing the top steering head nut; the one that is right under the fuse box. I have the right tool but it will not budge. Any suggestions as to how to release it would be much appreciated.
Ross
Ross
Re: Steering head bearing replacement
I would soak it with a quality penetrant, Kroil, PB Blaster, etc, NOT WD-40. Then take a large punch and hammer and "message" the outer edge of the nut. No need to hit hard, you don't want to be deforming anything. Light taps with a big hammer are much more controlable than whacking with a small hammer.
After a little soaking/tapping, it'll come right off.
- ajs350
Thanks. I used some penetrating fluid and a long breaker bar and off it came!
Ross,ajs350 wrote:Thanks. I used some penetrating fluid and a long breaker bar and off it came!
Kent has my steering head tools, including a spring scale and both special tools for both of those funky nuts. There are also bearing drivers and a race removal tool. They are due back to me in a few weeks, but I can detour them to you if you could use them.
I would advise carefully following the tightening instructions in the manual (in the '80 supplement?) or Mike Nixon's reprisal of them on his site.
http://www.motorcycleproject.com/motorc ... cking.html
I got mine too tight the first time and it weaved like a drunken sailor. Redid them with the spring scale and they came out perfect. Way better to do it right the first time
- ajs350
Nils
Dave was good enough to lend me his socket tools so I am good there. I will re-read the tightening instructions again to make sure I get it right.
Ross
Ross
hey guys
i have my frame back from powder coating and i am racing like mad to get Nils his tools back. i am all ready to do this but i have come across 1 snag. the lower steering stem bearing is giving me trouble! how the heck do you remove this as it is pressed on. the manual says to "remove if nesc." but it doesn't tell you how to "slide" it off the stem??? any advise. i even put the whole unit in the freezer and heated up the bearing hoping it would expand and slide off the frozen stem, no go. any quick advise would be much appreciated.
thanks a lot!
kent
thanks a lot!
kent
Kent, you've got 3 more weeks before I bloody my knuckles again. No worries.kbart1 wrote:hey guys
thanks a lot!
kent
This just got discussed in a different thread, Don and Dave describe driving the stem out of the lower triple, and the lower bearing race with it. Then you would of course have to drive the stem back in. For my part I Dremeled off the bearing but it was tricky and nervewrackng trying to avoid the stem with the cutoff wheel.
When I tear into the H2 I will drive out the stem.
