Sport Kit - What's included
ajs350
Post by ajs350 »
I'm considering looking for a sport kit for my 80. I believe these consist of foot plates, throttle switch cluster, gear linkage, handle bars and throttle cables. Am I missing anything?
Also I saw from another post that the spindle hole on the foot plates for an 80 is larger than the 79. Will a 79 kit work if I have the hole drilled out to the larger size or are there other differences too.
Ross
tevan
Re: Sport Kit - What's included
Post by tevan »
You can drill the hole out I believe. choke cable, left and right switches on bars.
The original "Sport Kit" does include a few parts you do not necessarily need. I see, that the clutch cable was not mentioned and neither was the brake pivot and the top brake line to the splitter, just to complete the whole list.
The only difference between 79 and 80 kit are the holes for the swingarm axle in the footpeg plates, as the 80 had a 16mm vs 14mm swingarm pivot axle. And the hole can be drilled.
EMS wrote:The original "Sport Kit" does include a few parts you do not necessarily need. I see, that the clutch cable was not mentioned and neither was the brake pivot and the top brake line to the splitter, just to complete the whole list.
The only diffrenec between 79 and 80 kit are the holes for the swingarm axle in the footpeg plates, as the 80 had a 16mm vs 14mm swingarm pivot axle. And the hole can be drilled.
Yeah, easy-peasy to drill those out. As mentioned the cables and brake lines are commodity items, and the throttle-side switch housing with the upward-facing cables can be sourced from other models. I'm pretty sure that my bars are slightly longer Interceptor bars. The brake spindle is really superfluous. The only parts you pretty much have to get OEM to get the setup (albeit not a true sport kit for the sake of the purists) are the footrests and the shifter linkage, and the shifter linkage could be reproduced easily if somebody would commission a batch of machined linkage rods.
ajs350
Post by ajs350 »
Thanks everyone. Now I know what I'm looking for!
Ross
