I have the standard pipes off my 80 and find that I can move center pipe from side to side. There is a clamp that holds it to the collector and it is fully tight. Is this normal for there to be movement or should the center pipes be clamped tight? TIA.
Ross
Standard Exhaust - center pipe loose
- ajs350
Re: Standard Exhaust - center pipe loose
Ross:
Most move a bit, but there is a collar gasket in there that may need replaced. They are still available from Honda. You'll see what I mean if you take one off.
- ajs350
I did not know those inserts were gaskets. Will get 2 new ones and re-install.
Ross
Ross
