Somehow I need to push the backet down, while turning the crank, just enough to clear the camshaft lobe. How very silly of me. Any ideas short of removing the camshaft and doing it properly?
Thanks, Aris
That would be my first attempt to free it up !6Pipes wrote:Another crazy thought.
Would the special tool used for valve shim replacement hold the bucket down while you rotate the cam?
I have decided to try this method and tomorrow I am fabricating a "ramped shim"6Pipes wrote:Aris,
I agree with Dave. Lifting the cam is the best way. I did have a crazy thought though. What if you cut a valve shim in half. Then grind a ramp on to the bisected half. Place it in your lifter body and slowly rotate the cam lobe so it rides up the ramp on to the remaining half of the valve shim.
Like I said, crazy thought...
