inner cam chain adjustment
DevonCbx
Post by DevonCbx »
In the shop manual it says to ajust the inner cam chain, loosen the lock nut. I donnot see a lock nut. I only see a nut by itself. The front cam chain adjuster has a lock nut. :x
Duane
Re: inner cam chain adjustment
You are seeing right, Duane. It is not a bolt with a lock-nut. It is two separate pieces. It is a bolt and a cap nut. The cap nut sits lower than the bolt. I have always loosened both. Maybe I did something wrong :? :? :?:
Mike:
If you are talking about the upper plain bolt on the rear tensioner - no you aren't supposed to loosen it. It is the mounting bolt for the whole tensioner. Just take the crank cap off, hold pressure forward with a wrench (to put all the chain slack on the tensioner side) and loosen the chrome cap nut a couple of turns. You will hear an audible 'click' as the tensioner snaps up the slack, if it's been a while since you adjusted it. Same procedure for the front.
DevonCbx
Post by DevonCbx »
How does the cap come off. Also there is rather very little space to work.
Duane
Duane:
You don't take the cap nut off - just loosen it a turn or so - the spring mechanism on the tensioner will take up the slack. If you're asking how to remove the crank cap - just the 3 Phillips screws. I'm sure you've had that off before.
Buy yourself the longest 10mm ratchet wrench you can find for the rear tensioner nut. It will work just fine. Absent that, just manually run a 10mm wrench with the tips of your fingers.
