In the center pages of the last CBXpress it shows Swiftys immaculate 79.
The second pic down on page 26 shows the cockpit and a view of the sport bars. Is this the correct way to have them or do I have mine on backwards??
sport bars
CBX Sports Kit Bars
Hi Broook,
The bar location of John Swift's 79 looks proper. In fact - if the handlebars are correct CBX Sports Kit parts - it is not possible to mount them "backwards" without removing the locating pins. And I would strongly recommend against such a modification since the pins are a safety feature. A quick snapshot of a right-side bar (Honda P/N 53120-422-000 for the '79 Z Model):
I have seen bars on eBay represented as "CBX Sports Kit" components but are from another Honda model (possibly a VFR). And while the shape is very similar to the proper CBX bars - the dowel pin location is much different. The pins have been removed to allow fitment on a 79/80 CBX triple clamp (less critical - the bar casting thickness also seems a bit thinner). Without these pins - a parking lot tip-over could be enough to pivot a bar into the fuel tank (even with the single pinch-bolt properly torqued). Having the bar move while riding could certainly be more costly.
A photo of the correct Sports Kit bars installed on my '80 Marysville CBX (note the pinch-bolt location from front to back at roughly a 45 degree inward angle - identical to the standard bars (this is also different on the "alternative" bars being marketed as CBX parts).
All the best,
John
San Jose, California
All the best,
John
Reason: Cleaned up HTML for PHPBB3
bars
Thanks for the reply John. Great pics. They describe exactly what I wanted to know. I guess like a lot of other people I now realise I do not have the genuine sport bars. I do like them though when compared to the stock high bars.
