Valve Tool
Valve Tool
My valve spring compression tool does not work on a CBX head. Does someone know of a tool I can buy that does work or do I have to find an arm and a leg to take to the Honda dealer for 07757-0010000?
- SteveG
Googled the part number, these guys claim to have that # for $66.95. No previous experience with them though.
http://www.lawnmowerpros.com/Honda-Parts.asp?Page=116
Steve
Steve
Thanks, Steve! I will check this out! That wouldn't be all that bad!SteveG wrote:Googled the part number, these guys claim to have that # for $66.95. No previous experience with them though.
Steve
If you have a welder available to you, one can be made using a 8" C clamp and weld a short piece of tubing (~1.5") to the swivel end. Cut a slice or 2 out of the length of tubing to access the keepers. Weld another short piece to the other end that will give you clearance into the head (about 3/4").
Tweezers, picks and a stick magnet will also be needed to grab those tiny keepers.
J.R.
J.R.
- Don
- Amazing Poster
Even if you don't have a welder . . . . those short pieces of tubing could be permanantly attached to the C clamp using Marine-Tex or any other similar eopxy and they would be permanetly on there. For years the hardware store dispays for Marine-Tex were a Coke bottle with a section of tire carcass glued to the side - You were 'invitied' to grab them and try to separarte the two
I would scuff up the metal on the clamp a little with a rough file and then fill the end of the tube with 1/4 inch or so of the epoxy and press them together by tightening the clamp for 24 hours - You'll never break it
Sure beats spending $75 . . . .
