Gas cap gasket?
Posted: Mon Feb 01, 2010 1:41 pm
by Terry
Yesterday I was cruising along the coast on my 82 and after 89 miles into a fill up I turned inland for some corner carving when I began to smell gas. I had to scrub off some serious speed to make a corner and after the turn I smelled it. As I looked down I saw a few droplets behind the gas cap on top of the tank. I guess after 97,000 miles its getting thinner or smaller or...in any event apparently needs replacing. Are they available or can they be made or can I use one from a more recently made bike?
Posted: Mon Feb 01, 2010 3:03 pm
Terry, I am a little confused... you need a new gas cap or just a gasket?
CB650 (Nighthawk) had the same gascap as the Prolinks...
Posted: Mon Feb 01, 2010 3:10 pm
by Terry
EMS wrote:Terry, I am a little confused... you need a new gas cap or just a gasket?
Hmmm, maybe you need to work on that Mike.
The closer I look at it the more I think it can't (be) replaced. Its ID is 1&1/2" and the OD is 2&1/2" but it has a lip that disappears under the leading edge of the whole cap! I tugged at it but it didn't seem that it was made come loose. I think I should be able to shim it maybe, with a thin gasket of similar size tucked under the inner edge that contacts the tank and seals it. The thread title states Gas cap gasket so that's what I thought I needed but...and TAS says Honda didn't list the gasket separately from the cap!
Posted: Mon Feb 15, 2010 1:11 pm
by SteveG
Posted: Mon Feb 15, 2010 1:28 pm
by Terry
Thanks Steve but all the ones on ebay are for early model caps.
