Hi all, does anyone in Oz know if the rear m/c can be re sleeved. Just went to the local brake centre and they said the 14mm bore is too small.
Cheers Moz
resleving rear master cylinder in Oz
- alimey4u2
- ICOA Web Video Director
I'm sure you can get it shipped. Use the "orignal" stuff it's far better then the newer fast cure "Kwik" version.
http://www.jbweld.net/faq.php
Sounds pretty incredible stuff regardless. I will see if it's available out here otherwise I have relo's in Bordon how can post.alimey4u2 wrote:I'm sure you can get it shipped. Use the "orignal" stuff it's far better then the newer fast cure "Kwik" version.
Cheers Moz
I was quite reluctant to use J-B Weld. With the packaging making such outrageous claims, it had to be junk, right?
Well, I followed the instructions of an older-but-wiser CBXer (Dave Ditner) and used it to repair a wheel caliper piston that was badly pitted. That was back in about '95. It's still on the bike, working just fine.
- Mike Barone #123
EMS wrote:One of the key things with JB Weld is temperature curing. If you can put the part in an oven and cure it at 180 degrees for 5-6 hours it improves the bond significantly.
Andddddd then....there are those non approved uses :suspect: :suspect: :suspect: :suspect: :suspect:
Issue
Aprilia Capo and 916 stock mufflers with holes where the small brackets to hold the mufflers together were removed
Fix
Mixed JB Weld with steel wool.....stuffed a bit in each hole...waited the specified time for it to dry....started the bike and let it idle for ten minutes. That was 24,000 miles ago...worked great.
