EXHAUST CHANGES PER YEAR
- twinegar
Did Honda use the same exhaust on the 79 and 80 or were they channeled differently inside for 80? The reason I ask is that my 80 sounds more like a 12 cylinder Ferrari. Maybe my 79 needs some valve work but it runs smooth as silk.
- twinegar
Would a welder be able to cut the #1 header pipe off at the bottom end near the shield and weld in another one? The is an 80 left side exhaust for sale that has a mashed area and because the 80 exhaust is different from the 79 I am thinking about grabbing it. Opinions please!
- twinegar
Ebay 290363166503.
Should I wait for another to show up? $100 seems a little steep.
- twinegar
Thanks, I set my bid sniper on and off three times before finally turning it off. How often have you seen 80 pipes for sale................anyone?
- twinegar
Any thoughts on pouring Rustoleum in the muffler to coat the bottom third and them pour out the extra? The area where the muffler welds to the down tubes is swelling but not through the chrome yet so maybe sealing the inside would extend the life a bit. A drain hole will be drilled also.
- twinegar
Not sure what the temp range is and I only mention Rustoleum because I read it here someplace. I had considered using liquid tar but again am not sure about the temp but it would probably smoke some at first and then lay down a gooey coating that would keep the moisture off. I read that Honda coated the inside of some of their exhausts with some sort of asphalt and it got me thinking. I was hoping I would trigger a discussion and someone would know more about it or had done it successfully.
- twinegar
I am definitely going to try something. I think tar would work considering how hot it is when they apply it to a road surface. I doubt that a bike exhaust at the muffler gets any hotter.
- alimey4u2
- ICOA Web Video Director
- Don
- Amazing Poster
