DRILL BIT
- twinegar
DRILL BIT
Once again I discovered a small pain in the a$$ problem created by a previous owner on my 80. The top oil filler cover bolt is twisted off and glued in to hide it. I haven't pulled the cover off yet but I am sure I will need to remove what remails of the bolt and want someone here to tell me what the hardest bit available retail is? I will try a reverse bit first but if that doesn't work I will need to drill it.
- Will
Re: DRILL BIT
What holds the oil filter in place?twinegar wrote:Once again I discovered a small pain in the a$$ problem created by a previous owner on my 80. The top oil filler cover bolt is twisted off and glued in to hide it. I haven't pulled the cover off yet but I am sure I will need to remove what remails of the bolt and want someone here to tell me what the hardest bit available retail is? I will try a reverse bit first but if that doesn't work I will need to drill it.
The hardest drills available are carbide. Tool & Die shops use them for drilling into hardened steel. The ones they use are helix ground and very expensive. They are for multiple use. You can get a lot less expensive one with a spade bit for a single use. They are used for drilling concrete and are readily available (Home Depot, Lowe's, our local hardware store)
That said, a cobalt drill will work fine for just about anything on a motorcycle.
Re: DRILL BIT
He is talking about the oil filler cover, i.e.: the transmission coverWill wrote:
- Will
Re: DRILL BIT
Oops. I'll have to slow down my reading, just like the rest of me.EMS wrote:He is talking about the oil filler cover, i.e.: the transmission coverWill wrote:
So, a bolt broke and the head got glued back on for cosmetic reasons. Usually enough of the bolt is still there to grab with a vice grips, especially if you grind a flat on the broken bolt to help hold it.
Those original bolts are relatively soft. You can drill them with anything sold for drilling metal. If it's a replacement Allen bolt, it shouldn't have broken, if it did, you may need a quality drill.
- twinegar
Actually it is the bolt closest to the dipstick and next to the shifter. http://www.spookytoms.com/SpookyTom-CBX-80-1-RB27.html
- twinegar
The new gasket arrived so I removed the left cover and found that the bolt had twisted off even with the hole but was able to drill a hole and use a B&D extractor to remove it. Someone had smeared a thick layer of JB Weld underneath from half way up the front to half way up the back of the joint where the cover mounts and from the crankcase to the outer edge of the cover to fix an oil leak. They sprayed it silver so I didn't notice until I pulled the cover off. My first thought with that much epoxy in place was that a major crack in the case or cover was being hidden but after a close inspection discovered the reality.
Take a look at the pile of epoxy I removed.
http://www.spookytoms.com/SpookyTom-CBX-80-1-RB16B.html
- twinegar
Because of the damage to the upper case and starter mounts it looks to me like they went ahead and broke the rest of it away to hide it. The spacer between the sprocket cover and case was missing also so had I broke a chain the damage might have been extensive. In order to avoid a case change I will probably use Marine-Tex to replace the missing curve. It worked great for the sprocket cover mount and starter mount and after painting looks and feels like metal. If I sold the bike some day I would disclose the repairs unlike the guy I got it from. Actually all the documentation anyone would need on any of my bikes is on my website.
