Rechroming for a grand?
Would it be worth it to rechrome your pipes for a grand? The promise is they would be as good as NOS as long as there are no soft spots or worn through sections.
Here is a part of an email regarding this,
..."Yes it will screw up the tanks if they are not prepped properly, we send the pipes out to be de-carbonized first, then we plate them like they are new material. My only concern would be if they have any serious corrosion spots that might "fall apart" in stripping or polishing. Anyway we can do them, not cheap though, complete CBX system about $1000-$1200."
I suppose this de-carbonizing process is when they'd truly find out if they would be worth doing.
Oh I understand completely. As a kid I worked in a muffler shop and remember mechanics using large waterpump type pliers and squeezing pipes with them trying to find weak spots to see if they were worth using. One of my single header pieces on the 79 has a weak spot near the bottom end, well, not actually a weak spot but more like a small section that's not there anymore!alimey4u2 wrote:I think you will find Terry that some metal is lost in the preparation. If the metal is paper thin in places it will come through....
