http://www.duraflowexhausts.com/index-page13.html
The bend is in the BSM exhaust also. The pictures do not show it well. I don't think it is for ground clearance, though. The muffler hangs on the brackets like the stock muffler. And the stock pipes have a slight indentation at that spot too.cbxtacy wrote:The bend in the pipe between the muffler and collector in the pipe Tony posted looks like there's a bend in it for clearance around the lower engine hanging bolt that would allow the pipes to give more ground clearance. Not that critical for most (how often do you drag stuff while cornering).
Yes Powerflow from Durban, South Africa. Distributor advised this.EMS wrote:I may have mixed that up. But the name was something with "flow" and the exhaust was different from the Pipemasters. Maybe it was Powerflow?
I don't think it was Duraflow...![]()
