fuel filter
fuel filter
I had written in earlier about slight sputtering at at steady speeds of about 100KMS. Could this be possible because I had put in an in line fuel filter? Is the filter sytem in the petcock enough
If you think your tank is starting to rust or is gunked up with gas residue an inline filter might help but i would get the tank cleaned/coated instead.
I got a tank of dirty gas once and it managed to get past two fuel filters.
My guess would be that a plugged fuel filter would cause a stutter throughout the rev range, not just at a certain spot.
- alimey4u2
- ICOA Web Video Director
Re: fuel filter
I would doubt it would cause the problem Duane . Is the filter in the petcock enough ? I have found too much residue in my carbs to believe it is, however that depends on the state of your tank & that of your gasoline supplier....DevonCbx wrote:I had written in earlier about slight sputtering at at steady speeds of about 100KMS. Could this be possible because I had put in an in line fuel filter? Is the filter sytem in the petcock enough
Unless there is a severe and permanent restriction, a fuel valve or filter will not cause fuel starvation. Figure this: Open your petcock and let a full tank of fuel drain into a can...how long does it take? 20 minutes? Now, do you think you can run your CBX in a mode that it will empty a full tank in 20 minutes? No? O.K.! That's why you don't need a high flow fuel petcock or remove the fuel filter. Enough liquid comes through there at any time to keep your motor going.
