Turn signal question
- GregW
Over the past month, my CBX's turn signals have been plagued by little electric "gremlins".
Intermittently, when I'd engage the button for the left turn signal, it would blink properly & then other times, blink awhile & quit completely. That seems to have passed, but now my right turn signal will stop blinking when I bank the bike hard right. Once upright, it blinks normally. If I take a turn easily, it blinks normally as well.
This is just plain weird. I've checked fuses & battery condition those appear normal. Would a flasher beginning to go bad do this? I'm looking for some ideas that I may not have thought of. The battery is 7 years old, yet specific gravity of the electrolyte is still within specs & the battery holds charge well.
If this is a connection problem, the left handlebar switch gear isn't something I can take apart & clean, is it? That's the one thing I haven't done yet.
Any ideas or related experiences would be appreciated. Thanks!!!
Greg
Greg
You can never have too many motorcycles.
- GregW
Chris:
Thanks for the reply. Now that I think about it, I had the forks off the bike back in May to replace the oil seals. When I put them back on, I repositioned the bars a tiny bit more rearward for better comfort. There appeared to be enough slack in the wiring from both right & left switch assemblies, however, with use, they could have loosened or tighented. I'll check them out this afternoon.
Thanks again!!
Greg
Thanks again!!
Greg
- Will
Re: Turn signal question
Over the years, I've found it is usually a ground that causes turn signal problems.
Look around the last place you worked. Then aim at checking all the ground wiring.
GregW wrote:Over the past month, my CBX's turn signals have been plagued by little electric "gremlins".
Greg
