Front fork play
DevonCbx
Front fork play
Post by DevonCbx »
I was wondering if it is normal to have front fork play. For example, if I hold the front tire with my knees and wiggle the handlebars from left to right the forks seem to twist a bit each direction. If this is normal, would a fork brace firm this up? I am in the process of restoring this bike. I have not ridden it yet.
alimey4u2
ICOA Web Video Director
Post by alimey4u2 »
Duane,There is a BIG difference between front fork flex & play. Yes, they flex & a good fork brace is a must (in my mind.) As for play there could be wear in the fork bushings ( two inside each lower unit) which are "fairly" easy to replace.....
Terry
Post by Terry »
"if I hold the front tire with my knees and wiggle the handlebars from left to right the forks seem to twist a bit each direction."
Not exactly a scientific way to make an accurate test except maybe on a bicycle. Both my Xs have braces. Haven't ridden the Prolink w/o one but frankly I can't tell any difference on the 79...but I won't be taking it off.
alimey4u2
Post by alimey4u2 »
Don't forget wheel bearings too Duane......
You get a better, quick feel for play in the steering neck if you lift the front end off the ground and try to rock the wheel back and forth.
DevonCbx
Re: Fork play
Post by DevonCbx »
As I checked my front forks, I did not have the front fender on. This I believe would brace the forks. I also intend to purchase a fork brace. Thanks everyone for the info.
Duane
