Stainless Fine-Thread Bolts, Screws, Nuts WANTED...
Does anyone know a source for fine-thread metric bolts, screws, and nuts? It's been a while since I posted this question, and I never found a supplier. They are not sold by McMaster-Carr, nor South Coast Stainless, nor Mr. Metric (my usual sources for hardware). I can turn one or two pieces, but when it's several parts, I'd rather spend the money. Cost is no object. No source is too remote. Canada? Europe? Japan? Any help much appreciated.
Leon
Leon
- Mike Barone #123
Re: Stainless Fine-Thread Bolts, Screws, Nuts WANTED...
At CBXman winter rally I saw some handsome shop based heavy duty plastic containers ....I estimate one for each of the following areas: nuts, washers, bolts, screws.......about 8 in all ....and each container had 16 or so smaller bins in it with different sizesBayArchitect wrote:Does anyone know a source for fine-thread metric bolts, screws, and nuts? It's been a while since I posted this question, and I never found a supplier. They are not sold by McMaster-Carr, nor South Coast Stainless, nor Mr. Metric (my usual sources for hardware). I can turn one or two pieces, but when it's several parts, I'd rather spend the money. Cost is no object. No source is too remote. Canada? Europe? Japan? Any help much appreciated.
Leon
You can call Dennis at CBXman for the source of these and he might take some photos for you and give you the source to buy them. http://www.cbxman.com/
No fine-thread metric hardware at MD Metric either...
Tried already--Maryland Metric doesn't carry fine-thread metric hardware either.
- alimey4u2
- ICOA Web Video Director
Thanks Mike, I "may" be able to find a custom maker but I'm sure they will be expensive.EMS wrote:Back in February, I went to three speciality stores and none had the specific sizes Leon wanted. It seems they are non-standard metric sizes and are not available as general merchandise, maybe not at all.
That's what the lathe is for...
Yes, several good people tried to help already. It's like trying to find aerosol epoxy paint in any color except white or almond. Demographics says it won't sell, so it isn't sold. I guess being at the end of a bell curve isn't so bad--at least it's not steep--or crowded. Anyway, I have a nice Emco Super 11 that cut's what I need, so this problem has been solved the expensive way--with lot's of my time. The bolts I wanted, by the way, were the stock engine frame bolts for the CBX, and the brake reservior cap bolts--but in stainless. Thanks for all your thoughts!
- alimey4u2
I love America, all you need is money & it shall be yours.....
http://www.americanfastener.com/customize.htm
I've been the stainless route, and it's a bumpy road. I have nearly any bolt you might need, including the engine mounts, both front and top.
BUT.....the frame mount bolts, the ones that also carry the oil cooler, are cut from longer bolts to get the proper thread pitch. Cut threads are not as strong as rolled threads, so I quit offering the kit. I'm running these bolts on my own bike, but I don't sell them any longer. This after spending quite a bit of money to have them special made, and with a high scrap rate. :-(
I have the master cylinder screws in stainless button heads. They look nice.
In fact, I have complete sets of stainless allen heads to dress up our bikes. Little things like the crank and cam end caps and tach drive. That kit, in chrome, used to be $27 from TIMS, and I was selling it for $6 in stainless allen head. Of course costs have gone up since then, but if there's interest. I still have a lot of stock.
Little things like replacing all the clamp screws on the handlebar switches, chainguard screws, license plate, Honda tank emblem, the acorn nuts holding the seat on the early models, etc,......all make a difference. Replacing all the carb screws and manifold clamp screws looks nice too, but is a lot of work.
