Carb swapping, immoral, deviant, or just plain wrong
retrex
Post by retrex »
Is it possible to swap early and later year carbs on the CBX? Are there any benefits to doing so? What are the main carb differences differences between the model years? Just one more piece of sacrilage, I have two spare sets of 4 cylinder 81 Suzuki GS1100 CV Mikunis, has anyone every swapped Mikuni carbs for the Keihins?
1982 Honda CBX - Mobile and loving it
1981 GS1100EX - Undergoing rebuild
1981 GS1100EX - Rolling rebuild
Why two GS11s? A man doesn't feel like a man unless he has a big pair.
It happens all the time. You will need to match the MM 29-34 depending on whats been done to the motor internally.
You will need to build a mounting rack, choke system, throttle cable and find rubber manifolds that will work.
No big deal if your handy or have a fat wallet.
383
jb
retrex
Frankencarbs mental exercise
Post by retrex »
I'm thinking that the standard Mikunis would probably be a bit to rich because they feed volumetrically a bigger cylinder, but that is a down stream problem. As I see it what you are saying is the problems to solve are as follows in roughly the order given.
1. Attaching the carb output openings to a modified intake boot system.
2. Attaching a left and right carb bank support support structure.
3. Attaching the left and right carb banks together, leaving enough space in between to rig throttle, throttle stop and choke gizmos.
4. Rigging a common throttle actuation system, that is a central gizmo that when you twist the throttle operates both the left and right carb banks in unison.
5. Rigging a common choke actuation system.
6. Rigging a common throttle stop
7. Running fuel supply lines of adequate flow rate
8. Air filtration system
9. Proper jetting
10.The unkown odds and ends.
Am I misssing anything? Jeez what could be easier that that. :shock: Er, ah, maybe I'll just clean and sync the carbs I have.
Dave Ditner
Carb Swaps
Post by Dave Ditner »
If there's any real advantage to the 82 carb set it's that the idle jets in those can be removed. They are screwed in verus the earlier ones being pressed in and being called "non serviceable"
Davey
retrex
Carb IDing
Post by retrex »
I just received a set of CBX carbs from an ebay purchase. How can I id what year bike they go to?
real6
Post by real6 »
What is the number on the side of the carb?
retrex
Will check
Post by retrex »
real6 wrote:What is the number on the side of the carb?
Sorry for the slow response I am not receving notification of replys for some reason. I will investigate tonight. The only thing I remember is a VB on the end carb.
retrex
Re: Will check
Post by retrex »
Sorry for the slow response I am not receiving notification of replys for some reason. I will investigate tonight. The only thing I remember is a VB on the end carb.
Computer Fart, how do I delete this post?
retrex
Carb ID #
Post by retrex »
I was finally able to look at the side of the carb and the number on it was VB 62HBRE7. I have taken the rubber carb insulators off the head that I am working on and they will all have to be replaced. They cracked and splintered as if they were made of hard plastic. Are these things still available?
real6
Post by real6 »
1979-model 422, carb VB60A: 1980-model 469, carb VB62A
retrex
Carb info
Post by retrex »
Thanks for the info real6.
Mike Nixon
...carb types
Post by Mike Nixon »
You may also like to look under the carb top to confirm that it is a 79. The 79 carb is unique in the respect that it has three atomizing circuits as opposed to the other carbs' two. The extra one -- the primary main -- has a brass air bleed orifice on the right side of the carb (looking from the saddle). See the picture below. If your carb looks like this, it's a 79 model carb. :-)
Mike Nixon
...carbs
Jeff -- Nice set of carbs. You're right about the wallet, though. :)
Re: ...carbs
Mike Nixon wrote:Jeff -- Nice set of carbs. You're right about the wallet, though. :)
Hey Mike, Ya I forgot to mention you can't buy them in bigger lots than 4 at a time, so you either have to buy 2 sets of 4=8 and eat 2 of them, or get someone else who wan'ts to do it and buy 3 sets of 4=12, ouch on the pocket book.
Its cheaper to put some later model SB's or CV's from a factory setup and just adapt them. The CBX doesn't really need all the carburetation unless the motor is a big bore and your going straight line racing.
jeff
Mike Nixon
...carbs and such
Jeff -- Yeah. You're right. There are a couple of retailers who are presently putting together sets of CRFs for us, but they are really spendy. There are some other alternatives. The bad thing about the CBX though, if trying to fit carbs from other models, is the CBX's odd manifold spacing. It's really tight, much tighter than most other bikes. Takes some reworking to make it work. But it's doable. It appears that our comrades in Britain have been doing interesting things with ZX6 carbs, and I have researched another route that I hope to follow up on one day. Those your carbs? Man, they look nice. Thanks for the reply. :)
