I'm thinking of replacing the stock front brake hoses on my 79 with stainless braided ones. Looks like the CBX suppliers out there have Russell, Galfer and Spiegler brands. Any experience/preference with any of these? How about pads.....any brand preferences? Thanks & have a nice holiday!
Steve
Front brake hoses
Front brake hoses
Have an Xellent day! Steve #5526
72 BMW R75/5 Toaster, 79 CBX
I've used both pre-made and self assembled lines, the latter from Goodridge. Both help braking feel. The difference is that the set I purchased covered w/ clear tubing got moisture inside the clear and now looks dirty, while on the self-assembled set, I covered with heat shrink tubing so they look nearly like stock lines.
I've put EBC pads on several bikes now and have been pleased with the results. Lines, pads, and careful bleeding will give you two-fingered stopping on an otherwise stock early model CBX.
- Mike Barone #123
Hi Steve
I took my old lines to a local airplane supply company and they had the right size lines in stock, then cut them to size for me.
Plus....they gave me a neat how to book for installing the aircraft fittings on the lines.
Cost was $80 or so and I sort of figure if the parts there were aircraft certified they should work on a CBX.
Another option doing it this way, is to buy a longer bolt for the master cylinder which they had in stock and run both lines from the master cylinder direct to the calipers vs going with one line from the master cylinder to the junction box and then two lines to the calipers. Saves on the fitting count and cost...plus reduces possible leakage points
Best
Best
The longer bolt you mention is already on your CBX, compliments of Honda. Just remove the bolt from the left side of the brake splitter. It has two hoses attached to it, one from the mc, the other to the right caliper.
I too did this mod, using russell hoses and dot-5 fluid, about 10 years ago. Brake feel is much improved, and bleeding is easier due to the horizontal air trap called the splitter being gone.
Robert Hill
Oklahoma City
Robert Hill
Oklahoma City
