Primary Shaft Alignment with Laser Level
JoeInTUS
Post by JoeInTUS »
I was installing a primary shaft today and it occurred to me that the laser level Nils has at the shop might be helpful and it was especially aligning the driven sprocket.
Performed Dave’s quick check with the clutch cover and ignition and the timing was spot-on
Joe S
Tucson, AZ
Re: Primary Shaft Alignment with Laser Level
:thumupp:
Excellent work Joe!
CBX-tras
Post by CBX-tras »
Nice to have.
But, if you don't, all I use is a tri-square.
