What is the best way to restore these exhauts
MagnusXII
Post by MagnusXII »
Im looking for some product which can help me to clean my exhauts. Any advise? I post some pic
Honda CBX 1047 pro-link (The Queen)
Suzuki GSXR 1000 k7
Suzuki VStrom 1000 k2
Dynamohum
Re: What is the best way to restore these exhauts
Post by Dynamohum »
WD40 to soak the oil/grease crud off and then Nevr-Dull wadding polishing cleaner. Takes some elbow grease but the results are worth it.
MagnusXII
Post by MagnusXII »
Dynamohum wrote:
Tue Dec 10, 2024 6:32 pm
Thanks ill try and post the results👌🏻
Suzuki GSXR 1000 k7
You are going to need some rubbing compound and 0000 steel wool first.
512tr
Post by 512tr »
Technically chrome does not rust, the rust you see is from the carbon steel underneath, when the protecting chrome plating becomes damaged or scratched the steel below starts to rust.
You will never get it back as new (without stripping the old chrome and re-chroming), but you can improve the look many times by removing the rust by polishing.
I’m using a polishing machine and an angle grinder with variable speed, with different polishing discs and different polishing compounds.
