Intake valves
Darrell
Intake valves
Post by Darrell »
I discovered different types of intake valves during the tear down.
Cylinders 1,3, and 4 have concave intake valves, whre 2, 5, & 6 are flat. Which are the correct ones?
I also see some kind of impact on pistons 4 & 5. No apparent damage to the valve surfaces tho. Do you think I should just start with fresh intake valves on all 6?
Re: Intake valves
The concave valves are aftermarket. Obviously replaced due to the incident evidenced on the piston. Those type of valves are what you will find as replacements. They are fine, just fiddly to lap.
CBX-tras
Re: Intake valves
Post by CBX-tras »
Kurt at KMCarburetor.com offers OEM quality Vesrah (OE supplier) valves for the CBX. Reasonably priced.
https://www.kmcarburetor.com/products/h ... take-valve
I just installed a complete set last week.
There are valves out there that have raised lettering on them that are near impossible to lap. Avoid them. Sold by K&L.
The piston damage appears to be a keeper, stem or spring failure.
Darrell
Re: Intake valves
Post by Darrell »
Many thanks! Super helpful!
