Float bowl drain tubing
Artie
Post by Artie »
https://www.ebay.com/itm/313021909867
These are thin and flexible inexpensive
I never had drain lines before but needed to make it easier to drain carbs
anytime my 79 Z was going to be sitting for 2-3 weeks so finally put tubing back along top of motor 3 on each side long enough so they go between swing arm and engine long enough so I can just put small pan on each side to drain carb’s easily and quickly
Of course they are each individual separate lines
