How to add hazard switch
I was wondering if anyone tried to add a hazard switch. I know that it is not required but good to have when you are on the road, for example, to prevent rear ended.
Re: How to add hazard switch
I have a Hazard switch, but have a complete custom wiring in connection with the M-unit.
The emergency lights are very useful, this summer I used the Hazard lights 2 times, once when I had to stop for a herd of 20-30 reindeer in the middle of the road, the other time when I was the first after a car accident.
Here is a simple diagram you may use to wire up a Hazard switch.
Thank you. With a wiring diagram this should be a relatively easy installation.
