Oil cooler hose replacement
Posted: Mon Mar 27, 2023 7:29 am
by scottish CBX
I think I know the answer to this question but I hope the experts out there will prove me wrong - is there a way to replace both of the oil cooler hoses without removing the air box and all that this entails - engine tilt, carbs moved away from air box etc. The problem is that the crimped ends of the oil cooler hose will not pass the air box as is, darn.
So is it just a case of tilting the engine forward, move the carbs away from the air box and then wiggle the air box away from the air cleaner to gain enough space to remove/fit the oil hoses? Of course, if I had lengths of new hose, crimps and a crimper, I could do this in-situ without all this fuss.
Inputs please. Thanks
Re: Oil cooler hose replacement
Posted: Mon Mar 27, 2023 8:32 am
by tevan
The best way that I have found is just to tilt engine. I make the hoses if you don’t have anyplace closer. I am in USA. I do need your ends unless you want to purchase some from me.
Posted: Mon Mar 27, 2023 8:35 am
by CBX-tras
Tilt the motor but, just unclamp the airbox from the filter box. Remove the 2 bolts on top that go through the frame and the large band clamp between the 2. No need to touch the carbs.
Posted: Wed Mar 29, 2023 3:22 am
by scottish CBX
Many thanks. I'm glad that I only have to change these once as the originals lasted 45 years and I won't be the one to change them ever again.
Posted: Wed Mar 29, 2023 6:06 am
by tevan
I know what you mean. Once and done.
Posted: Sun Apr 02, 2023 12:54 pm
by scottish CBX
tilting the engine worked fine, I used a block of wood secured to a scissor jack in front of the two holes in the crankcases at the bottom - just in front of the sump pan and just behind the oil filer housing. I did discover that despite loosening the single jubilee clip for the connection from the air box to the inlet manifold, the manifold pulled itself away from the airbox ever so slightly at the top. Not to worry, some WD40 and jacking the engine back into place it lined up again. A very blunt screwdriver was used to gently coax the rubber back into it's seat, let's hope it is still sealed properly.
So if you are attempting this, loosen the one jubilee clip and then ease off the rubber between the air filter box and inlet manifold, this will make life easier and will be a much better guarantee of getting a reliable seal afterwards.
Posted: Sun Apr 02, 2023 11:15 pm
You can also fiddle that rubber into position by removing the air filter and reaching through the air filter chamber, guide it from the inside.
