Alternator drive plates
igotadizzy
Post by igotadizzy »
Is anybody manufacturing new alternator drive discs, as mine are totally shot inner plate being worn to the point that the 4 radial grooves from inner to outer are almost flush. Also are they all supposed to have 2 washers behind this plate to push on the spring as mine only has the one.
Re: Alternator drive plates
Yes, there are two washers.
Two different thicknesses. Both are becoming difficult to find as are the plates.
https://www.motorcycleproject.com/text/ ... lutch.html
Might check with David Silver or cmsnl.com for the plates if they can't be resurfaced.
Always can ask Louis Mintrone at usedcbxparts.com
tevan
Post by tevan »
Look up Cary knapton. I believe he is in the uk. He has been putting fiber plates on them with good results. I believe if you send your plates in to him he applies the fiber for you.
hondaman160mph
Post by hondaman160mph »
Do a search here, tons of info on this subject.
TrueDisc LLC will resurface your plates including cutting
in the 4 oiling groves for about $200.00. Get a shim washer from Mike Nixon and the washer you're missing
from Louis.
