HL Switch 750Fe RH Control Unit Headlight Switch
Au-CBX
Post by Au-CBX »
Hi,
I have a 1985 CBX750Fe with a stuffed headlight switch in the RH control pod/unit that has the throttle cable coming out of the bottom.
Any ideas where I can get either the slide switch or a whole right hand control unit with the kill and star button on it.
Also, not sure why but when I put the rear brake on, the headlight comes on if it is turned off. Once the brake is released, the headlight goes off again.
Re: HL Switch 750Fe RH Control Unit Headlight Switch
You may find the switch here:
https://www.cmsnl.com/honda-cbx750p-198 ... 4BYq4uSmUk
Only one i could find. Don't know if it is the same as on your bike
Au-CBX
Post by Au-CBX »
Thanks EMS for the information.
I had tried there and it is beyond my budget.
I will keep trying but may have to make my own mods.
