Gearbox Sprocket
cbxchris
Gearbox Sprocket
Post by cbxchris »
Could someone please confirm ( or not) that the gearbox output sprocket what drive's the chain to the backwheel, should have a small amount of movement on it when the securing bolt is tight, thanks in advance CBX Chris
Re: Gearbox Sprocket
Don't know if it is supposed to be for cushioning or alignment but with a new sprocket and no visible wear on the shaft there is small amount of movement.
cbxchris
Post by cbxchris »
steve murdoch icoa #5322 wrote: Mon Oct 05, 2020 7:00 am Don't know if it is supposed to be for cushioning or alignment but with a new sprocket and no visible wear on the shaft there is small amount of movement.
Thanks Steve, i think they come as std like that, i'm supprised the fidgiting does'nt wear the splines out !
