engine rebuild
You are seeing roughly half of our forum - what's here, how to register to see the remainder
martin phillips
engine rebuild
Post by martin phillips »
hi ive just purchasedc a cbx 1000 1979 model american import , took engine out and started to take rocker cover off and i think the bike has been under water at some stage and i drained the oil or i should say water out , its been awhile in there ,not sure if you know a engine rebuilder , i can do engine building but i think this one will need reboring cams reprofiling etc, any thoughts pleasw ,cheers Martin
Re: engine rebuild
Not a pleasant find. Were you misled on the condition of the engine?
Have a wander around on https://ukcbxclub.com/ Probably find a couple "local" engine builders on their site.
Please do come back and let this site know about your results.
btw, i have friend that lived in your area[Torpoint] for 40 years before moving to Canada. She has lots of pics of great roads along the coast.
jnnngs
Re: engine rebuild
Post by jnnngs »
Martin,
Welcome to the ICOA!
The go to guy for engine builds in the UK is Carl Woodcock - based in the North West.
He is normally booked up for a while, so would need to schedule it in with him.
I also do Engine builds, but just too many other projects getting in the way to do it for you at the moment.
Send me a PM if you want me to put you in contact with Carl.
Paul.
Re: engine rebuild
Welcome Martin, good luck with the rebuild, keep us posted!
martin phillips
Re: engine rebuild
thanks for your comments i think i was misled with the condition of the engine , i think i will brave it and settle down to a full strip down ,and see what i find hopefully it wont be as bad as im fearing ,will keep you posted
Re: engine rebuild
Here's to it, mate. Best of luck.
Return to “New Users - Start Here”
