Removing bar ends
Posted: Mon Mar 16, 2020 11:44 pm
by DaveMadsen
Putting a 1979 together and I see one of the bar ends is missing. I thought I would remove the other but want understand how it is attached to the handlebar. I assume it is threaded, but for the life of me I can’t break free the remaining bar end (it is the left side so may be susceptible to water/rust. Can someone confirm if the bar ends are threaded (and if they have reverse threads - I don’t want to be cranking on it only to find out I am trying to turn it the wrong way)?
Re: Removing bar ends
Posted: Tue Mar 17, 2020 3:57 am
by jnnngs
Yes, threaded (not reverse threaded)
They do stick, but normally come off OK with a little brute force. You could try some heat - that will probably help.
Paul.
Posted: Tue Mar 17, 2020 6:08 am
by tevan
I bet it won’t come out easily because it has never been out. The other guy probably tried it and gave up. I have extra bars if you have a bad experience. Good luck.
Posted: Tue Mar 17, 2020 7:12 am
Heat
Posted: Wed Mar 18, 2020 5:45 pm
by DaveMadsen
Thanks, I solicited the help of a 2' breaker bar and the bar end came around to my way of thinking. Now, two questions: (1) where can I get another bar end to replace the one which was missing, and (2) any recommendations on non-OEM bar ends, preferably ones which would use the same threads.
Again, thanks for everyone's suggestions.
