cam buckets
relisysxx
cam buckets
Post by relisysxx »
Hi all, Could some explain (photo would be good) the difference between the markings on the 'A' cam follower buckets and the 'B' type, I've looked at mine and can't see any difference (motor came in bits).
Thanks in advance.........Nick
jnnngs
Re: cam buckets
Post by jnnngs »
Hi,
There are marks by the cutouts on the top surface of the bucket (the mark is like a grind mark which you can see when the light catches it).
A "B" bucket has a mark on one side of each cutout. The "A" bucket has a mark on both sides of each cutout.
Paul.
Re: cam buckets
Unfortunately, the early model shop manuals don't make this clear. Here is a photo from the Pro-Link manual, that describes this very well.
relisysxx
Re: cam buckets
Post by relisysxx »
Thanks, a lot clearer now, my head has all 'B's as it should have. Unfortunately most of the exhaust buckets seem a bit tight, am I right in thinking the 'B's are the looser of the two? Any other reasons for them being tight?
Re: cam buckets
They are a tight fit. There is very little difference between A and B buckets.
