They visually seemed fine at the start, so I put all the exhaust valves in and everything looked good.
But when I started putting the intakes in....I believe there is a problem.
The exhaust valves stick out beyond the retainer as the originals did.
But the intake valves are set in at same level or lower than the retainer.
Either the seats were cut too deep and tops of valves cut off to compensate for shims, or the lock was machined in the wrong spot.
This isn't the way they should be.....no clue what issues I would have with finding shims too.
intake side
exhaust side
