Need advice on something
- ksquared
I would like to remove the bolts that clamp the steering stem so that I can refresh the reflector brackets. Can I remove both bolts on one side and not mess up the stem position on the fork? I'm talking about item 8 on the attached graphic. My reflector brackets, item 2, need paint.
Re: Need advice on something
You can take them out no problem.
- ksquared
Thanks tevan. Would you or anyone here know how much torque should be used for those 4 acorn nuts?
- cross
abt 13-18 ft-lbksquared wrote:Thanks tevan. Would you or anyone here know how much torque should be used for those 4 acorn nuts?
Sasha
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
- ksquared
Thanks! After seeing that figure, I realized it was probably in the shop manual that I haven't yet had a chance to view.
- cross
No worries. Manual has torque values at the beginning of each chapterksquared wrote:Thanks! After seeing that figure, I realized it was probably in the shop manual that I haven't yet had a chance to view.
Sasha
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
