Hi,
Just finished stripping the engine on a bike that I finished earlier in the year.
The bike ran fine for about 100 miles, then started knocking at higher revs. Having stripped the engine turns out there is a lot of wear on the crankpin journal for cylinder #2. The shells have disintegrated and the crankpin itself has worn (now measures around 35.4, should be a touch under 36).
Every thing ese looks fine on the bike - no signs of wear on any of the other crankpins / main bearings.
What can cause this? Oil ways to that crankpin look OK, and I plastiguaged it when I rebuilt the engine and everything was in spec.
In the sump pan, there is a small amount of debris - looks like very small fragments of copper - is this just the disintegrated bearing shells? Not sure what else it could be?
Concidentally, I have another engine which has a similar problem. Bike had been standing for 25 years, and when I stripped the engine crankpin #6 was badly worn. Not got round to fixing this one yet!
Is worn crankpins a common problem - if so, caused by what?
Paul.
Crankshaft Problems
Jump to
- ↳ New Users Start Here!
- ↳ Daily Discussion: By, For & About CBXers
- ↳ No Redeeming Value
- ↳ Project Threads
- ↳ Rally & Ride Questions & Post Event Reports
- FORUM USER TIPS, HELP DESK & POSTING TEST LAB
- ↳ Help Desk Questions for Using Forum
- CBX TECHNICAL LIBRARY: Answers For All Your CBX Questions
- ↳ New Users - Start Here
- ↳ BRAKES: Calipers, Pads, Lines, Rotors, Upgrades & Fixes
- ↳ CARBS: Cleaning, Rebuilding, Swaps, Aftermarket, Tuning, Syncing, and More
- ↳ ELECTRICAL: Alternator, Batteries, Headlights, Switches, Tailights, Wiring....
- ↳ EXHAUSTS: What works and fits...and what doesn't.
- ↳ ENGINES: Maintenance, Performance, Parts Sources
- ↳ HANDLING: Suspension, Gearing, Frame Bracing, Non X Handling Part Upgrades, Rim Replacement Options, and more
- ↳ OILS: Specs, Opinions, Preferences, and more
- ↳ RESTORATIONS: Tips, How To's & What Not to Do. Parts, Decals, Painters, Paint Codes, Painting Tips.....More
- ↳ TIRES & RIMS: Tire Brands, Mileage, Performance, Sizes, Interchangeability with other models
- ↳ X ...OTHER TECHNICAL: Won't Run, Centerstands, Chains, Fairings, Tanks, Gauges, Petcocks, Seats, Turn Signals, etc.
- ↳ RIDER GEAR: Boots, Gloves, Helmets, Jackets, Leathers, Rainsuits, Textile Suits
- ↳ CBX Parts & Accessory Suppliers, Dealerships, Mechanics, OEM Parts, Speciality CBX Shops
- ↳ 4 Sale/Wanted -or- Links To Great Items 4 Sale
- ↳ Dan picks the best Videos, Pix, Want Ads, Technical and General Posts Each Week For Us. Amazing recaps.
