The rubber strap holding up the plastic storage tank under the rectifier has snapped. It appears this is NLA.
Any ideas on a repair or a substitute? Used ones are probably perished as well so I haven't looked at those.
Rubber strap broken on plastic storage tank
- CopperCollar
Re: Rubber strap broken on plastic storage tank
The only one I have found is from Louis.
There may be other bands from other makes that will work. I think its about 25mm width and 210mm length.
I have a busted one in the shop. I'll measure it later and post the results.
Superglue works really well in exactly this situation
Cheers
Cheers
