Cbx 1000 z frame number
Littleeagle28
Post by Littleeagle28 »
Have a 1979 cbx 1000 frame. Does anyone know a method for detecting the frame number, as appears to have been rubbed away?
Re: Cbx 1000 z frame number
I've had cables mess up a vin plate but never wear away the stamped numbers on the steering stem.
Mouse
Post by Mouse »
Honda replacement frame? :think: Thus, no number stamp?
Littleeagle28
steve murdoch icoa #5322 wrote:I've had cables mess up a vin plate but never wear away the stamped numbers on the steering stem.
I think it was either deliberately removed, or is a new replacement, as it is in as new condition.
Littleeagle28
Mouse wrote:Honda replacement frame? :think: Thus, no number stamp?
As it is in as new condition, then this might indeed be the case?
Some of the replacement engine cases came with no i.d. numbers but i have not heard of frames coming like that.
Any chance the frame has been powder-coated and the numbers are just filled-in?
If you have some paperwork with numbers you might try sending them to EMS. Mike MIGHT have some info on your bike.
