Last year I rebuilt the front calipers on my 79/80 CBX -- not with new parts, just a thorough cleaning and reassembly of what was there.
Now, a year later, I took the bike for its first post-rebuild ride and the front brakes worked fine initially, then started dragging and --finally -- locked up completely.
I loosened the bleed screws slightly and fluid squirted out under pressure. That allowed the caliper pistons to retract enough to get me home, but now I need to do the job right.
What would prevent those brake pads from retracting properly??
-- PW
79/80 CBX Brake binding
blockage
During your cleaning you have dislodged some of the crystal like substance that forms in the system, a piece has now found its way to the master cylinder and plugged the return hole in the M/C reservoir. take a very fine wire (i use different size guitar strings) to dislodge the blockage and flush your system with fresh fluid.
jeff
jeff
