Hi,
I have a tims replacement alternator which is leaking oil from the bottom of the alternator cover.
I have seen a topic with pictures on this subject, but I have searched and I can not find it,
The spigot is in the end of the shaft ok, there is rubber seal on the alternator casing which seem ok,
When I remove the alternator there is a pool of oil in the bottom of the engine casing, and this is were it drips from.
Any ideas on how to fix it.
Neil
Tims replacement alternator weeping oil
Re: Tims replacement alternator weeping oil
I couldn't find it either Neil but there was/is a thread from paullavery on CBXWorld with some similarities.
An older one from Ray as well.
thanks steve,
i will have a look to see if i can find it there.
cheers
neil
cheers
neil
found this on the cbxworld site.
mine is all correct with the guard etc.
so i guess it must be the rubber seal that goes between the engine case and the alternator.
this is the link hope it works.
http://www.cbxworld.com/modules.php?nam ... r&&start=0
Another that might help, Neil. viewtopic.php?f=21&t=8094&p=62003&hilit=oil+leak#p62003
