One method requires fixing the decal in place with masking tape and the other uses a water soap mixture. The masking tape method looks okay for large and compact decals but the long skinny tank stripes don't seem to be suited to the masking tape method, one error with those wiggly stripes and I'll have a problem.
If I were to use the water/soap method are all decals water resistant? This would seem to give me the most forgiving for placement errors.
The supplier said I should lay them over the last clear coat, I'd prefer them under a clear coat like the oem decals but I've read that some decals will shrivel up when sprayed with a clear. And if I want to clear them I'd also need to do it within a 24 hr window from earlier coat which is problematic as then the color coat under the decals is still curing?
If anyone has any suggestions or practical experience to share I'd appreciate it.
