PostPosted: Thu Aug 18, 2016 1:03 am Reply with quote Edit/Delete this post Back to top Delete this post
My brother wanted to get set up to change tires and since I had already gone through this whole ordeal I made a vid of my entire setup.
I go through and do a tire change on my CB1100F gold boomerang without adding any scratches. The equipment works great but I am just an amateur and don't change tires all that often, so I lack the grace you would see in a professional.
https://www.youtube.com/watch?v=aP-PQILeCZc
Harbor Freight Items used
Motorcycle tire attachment (note, I welded a plate to the bottom and bolted it to my milling machine table, it is supposed to mount on the harbor freight tire changer for cars)
http://www.harborfreight.com/motorcycle ... 60810.html
Bead Breaker (I use this for both cars and motorcycles, handy tool)
http://www.harborfreight.com/bead-breaker-92961.html
Wheel balancer (not in vid but needed, unless you use dynabeads)
http://www.harborfreight.com/motorcycle ... 98488.html
No Mar items
Tire Lube (required, mounting is no fun without LUBE!)
http://www.nomartirechanger.com/Tire_Lu ... -paste.htm
Grip Spools (to grab the rim)
http://www.nomartirechanger.com/Standar ... andard.htm
Demount tips (pop it in the end of a piece of 3/4" pipe)
http://www.nomartirechanger.com/Demount ... p-dt3b.htm
Mount Tips (made my own mounting bar)
http://www.nomartirechanger.com/Mount_T ... p-mt2b.htm
Yellow thing (life saver)
http://www.nomartirechanger.com/YellowT ... wthing.htm
Harbor frieght motorcycle tire changer
Re: Harbor frieght motorcycle tire changer
Thank, ya, Colonel. Good demo
