Hello Gents,
Once again I need to dip into the font of knowledge,
The oil pipe from the crank to the cylinder head, The top banjo bolt (front of carb 4) is this a special
size bolt as I can’t seem to find one that fits & this one banjo is stopping the rebuild.
regards
Edd.
banjo bolt stops progress
Re: banjo bolt stops progress
It is a special bolt indeed. It is more then a bolt I think it has a orfice built into it somehow. It is nothing like the brake banjo bolt. I would find the correct one. The top one is different then the bottom one.
Edd,
If you need one of these bolt's I think I have one - I'll PM you.
Paul.
Paul.
