Float bowl over flow tubes
Posted: Mon Feb 15, 2016 11:36 am
by tevan
I have a leaking over flow tube. It is cracked all the way to the base. Soldering it did not get it because it must be cracked where it pushes in the alum body. I am wanting to put a new stem in but is there a sealant that will withstand being submerged in gas that will hold up?
Re: Float bowl over flow tubes
Posted: Mon Feb 15, 2016 2:34 pm
Years ago i used this stuff to seal a split in a chain saw gas tank.
Only used non-ethanol gas since and it did not leak. The chain saw has since been binned
http://www.totalmotorcycle.com/reviews/ ... Review.htm
Posted: Mon Feb 15, 2016 2:36 pm
Here is a proper fix. Way out of my league.
http://cx500forum.com/forum/general-dis ... ement.html
Posted: Mon Feb 15, 2016 7:44 pm
by patzx12
Change the float bowl, dont faff about fixing.
There are a lot of Honda models with the same float bowl.
Have a rummage around a local friendly breaker.
Posted: Tue Feb 16, 2016 11:05 am
by Larry Zimmer
Thanks for the 'patch' and the suggestions, guys. I expect this should be big help to some folks.
Posted: Tue Feb 16, 2016 11:12 am
by tevan
steve murdoch icoa #5322 wrote:Here is a proper fix. Way out of my league.
I am going to have a go at this method when I get time. Thanks for the link.
Posted: Tue Feb 16, 2016 10:57 pm
by FalldownPhil
Nice article,
Thank you for posting it.
Phil
